Salta al contenuto principale
Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement
Cosa ti serve
  1. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: passo 1, immagine 1 di 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: passo 1, immagine 2 di 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: passo 1, immagine 3 di 3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 2, immagine 1 di 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 3, immagine 1 di 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 3, immagine 2 di 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 3, immagine 3 di 3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 4, immagine 1 di 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 4, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 5, immagine 1 di 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 5, immagine 2 di 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 5, immagine 3 di 3
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: passo 6, immagine 1 di 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: passo 6, immagine 2 di 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: passo 6, immagine 3 di 3
    • Locate the two solder points corresponding to the malfunctioning vibrational motor.
  7. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 7, immagine 1 di 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Desolder the two connection points corresponding to the malfunctioning vibration motor.
    • Once the solder has been sufficiently melted, carefully pull the wires away from the solder point with tweezers.
    • For help with soldering best practices, check out this Soldering and Desoldering Connections Guide.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 204
