Salta al contenuto principale
Beboncool Gamepad for Nintendo Switch Joystick Replacement
Cosa ti serve
  1. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: passo 1, immagine 1 di 3 Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: passo 1, immagine 2 di 3 Beboncool Gamepad for Nintendo Switch Joystick Replacement, Beboncool Nintendo Switch Gamepad Disassembly: passo 1, immagine 3 di 3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 2, immagine 1 di 2 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 3, immagine 1 di 3 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 3, immagine 2 di 3 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 3, immagine 3 di 3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 4, immagine 1 di 2 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 4, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 5, immagine 1 di 3 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 5, immagine 2 di 3 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 5, immagine 3 di 3
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Joystick Replacement, Joystick: passo 6, immagine 1 di 2 Beboncool Gamepad for Nintendo Switch Joystick Replacement, Joystick: passo 6, immagine 2 di 2
    • Remove the joystick cover from the joystick actuator by firmly pulling the cover away from the actuator.
  7. Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 7, immagine 1 di 2 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 7, immagine 2 di 2
    • Gently separate the battery pack from the back of the motherboard, leaving it connected to the board through its lead cables.
  8. Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 8, immagine 1 di 1
    • Bend each of the retaining tabs located in the the corners of each joystick actuator straight so that they can be removed.
    • If only one of your joysticks is showing issues, just address the pins corresponding to the problematic joystick.
  9. Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 9, immagine 1 di 3 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 9, immagine 2 di 3 Beboncool Gamepad for Nintendo Switch Joystick Replacement: passo 9, immagine 3 di 3
    • Desolder the 12 soldering points connecting the problematic actuator(s) to the motherboard.
    • Remove the actuator from the board.
    • For help with soldering best practices, check out this Soldering and Desoldering Connections Guide.
Conclusione
Un commento
Me who used my no longer existing nails for the grips lol
TheGuyInTheChair - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 556
