Salta al contenuto principale
Beats Studio3 Wireless Speaker Replacement
Cosa ti serve
  1. Beats Studio3 Wireless Speaker Replacement, Ear Pad: passo 1, immagine 1 di 2 Beats Studio3 Wireless Speaker Replacement, Ear Pad: passo 1, immagine 2 di 2
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
  2. Beats Studio3 Wireless Speaker Replacement: passo 2, immagine 1 di 3 Beats Studio3 Wireless Speaker Replacement: passo 2, immagine 2 di 3 Beats Studio3 Wireless Speaker Replacement: passo 2, immagine 3 di 3
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
  3. Beats Studio3 Wireless Speaker Replacement, Speaker: passo 3, immagine 1 di 2 Beats Studio3 Wireless Speaker Replacement, Speaker: passo 3, immagine 2 di 2
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
  4. Beats Studio3 Wireless Speaker Replacement: passo 4, immagine 1 di 3 Beats Studio3 Wireless Speaker Replacement: passo 4, immagine 2 di 3 Beats Studio3 Wireless Speaker Replacement: passo 4, immagine 3 di 3
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
  5. Beats Studio3 Wireless Speaker Replacement: passo 5, immagine 1 di 3 Beats Studio3 Wireless Speaker Replacement: passo 5, immagine 2 di 3 Beats Studio3 Wireless Speaker Replacement: passo 5, immagine 3 di 3
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
Conclusione
Nayeli watts
Membro da: 03/16/23
474 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 95
Tutti i Tempi: 954
