Salta al contenuto principale
Beats Studio 2 Wireless Battery Replacement
Cosa ti serve
  1. Beats Studio 2 Wireless Battery Replacement, Battery: passo 1, immagine 1 di 2 Beats Studio 2 Wireless Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: passo 2, immagine 1 di 2 Beats Studio 2 Wireless Battery Replacement: passo 2, immagine 2 di 2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: passo 3, immagine 1 di 1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: passo 4, immagine 1 di 1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: passo 5, immagine 1 di 3 Beats Studio 2 Wireless Battery Replacement: passo 5, immagine 2 di 3 Beats Studio 2 Wireless Battery Replacement: passo 5, immagine 3 di 3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
Conclusione
Altre 2 persone hanno completato questa guida.
Jack Wilson
Membro da: 03/20/23
494 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 180
Tutti i Tempi: 2,313
