Salta al contenuto principale
Beats Solo 3 Charging Port Replacement
Cosa ti serve
  1. Beats Solo 3 Charging Port Replacement, Charging Port: passo 1, immagine 1 di 1
    • Use a nylon or metal spudger to carefully remove the ear pad from the right ear cup.
    • Be careful to not rip the ear pad fabric with your tools.
  2. Beats Solo 3 Charging Port Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the seven screws that hold the speaker in place.
    • There are two screws in the big red circle at the bottom.
  3. Beats Solo 3 Charging Port Replacement: passo 3, immagine 1 di 1
    • Desolder all wires connecting the circuit panel to the rest of the device.
    • There are two wires in the big red circle at the bottom and one in the small red circle above.
  4. Beats Solo 3 Charging Port Replacement: passo 4, immagine 1 di 2 Beats Solo 3 Charging Port Replacement: passo 4, immagine 2 di 2
    • After you desolder all wires you are able to remove and replace the charging port.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 128
Tutti i Tempi: 4,995
