Salta al contenuto principale
Beats Solo 3 Battery Replacement
Cosa ti serve
  1. Beats Solo 3 Battery Replacement, Battery: passo 1, immagine 1 di 2 Beats Solo 3 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: passo 2, immagine 1 di 1
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: passo 3, immagine 1 di 2 Beats Solo 3 Battery Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: passo 4, immagine 1 di 2 Beats Solo 3 Battery Replacement: passo 4, immagine 2 di 2
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Where too buy battery?
GSD - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 30
Ultimi 7 Giorni: 142
Ultimi 30 Giorni: 634
Tutti i Tempi: 12,419
