Salta al contenuto principale
BLU Dash JR D140 Microphone Replacement
Cosa ti serve
  1. BLU Dash JR D140 Microphone Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Microphone Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Microphone Replacement, Microphone: passo 3, immagine 1 di 1
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Microphone Replacement: passo 4, immagine 1 di 2 BLU Dash JR D140 Microphone Replacement: passo 4, immagine 2 di 2
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Microphone Replacement: passo 5, immagine 1 di 1
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Microphone Replacement: passo 6, immagine 1 di 1
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Microphone Replacement: passo 7, immagine 1 di 1
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Microphone Replacement: passo 8, immagine 1 di 1
    • When the ribbon cable is removed from the ZIF connector, peel off the power sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Microphone Replacement: passo 9, immagine 1 di 1
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Microphone Replacement: passo 10, immagine 1 di 1
    • Separate the screen cover from the motherboard using the plastic opening tool.
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
  11. BLU Dash JR D140 Microphone Replacement: passo 11, immagine 1 di 3 BLU Dash JR D140 Microphone Replacement: passo 11, immagine 2 di 3 BLU Dash JR D140 Microphone Replacement: passo 11, immagine 3 di 3
    • The microphone is at the bottom left corner of the phone.
    • Lift the microphone very carefully. Unsolder the two lower wires (one red wire and one black wire).
    • If you don't feel comfortable with this step I recommend looking at Ifixit's solder guide here.
    • Solder the new microphone in the same spot. The black wire will go in the left spot and the red wire in the right spot.
Conclusione
Altre 2 persone hanno completato questa guida.
UW Tacoma, Team 1-4, Liner SU 2015 Membro di UW Tacoma, Team 1-4, Liner SU 2015
UWT-LINER-SU15S1G4
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 511
