Salta al contenuto principale
Azpen A740 Speaker Replacement
Cosa ti serve
  1. Azpen A740 Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Speaker Replacement, Speaker: passo 2, immagine 1 di 2 Azpen A740 Speaker Replacement, Speaker: passo 2, immagine 2 di 2
    • The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver.
  3. Azpen A740 Speaker Replacement: passo 3, immagine 1 di 2 Azpen A740 Speaker Replacement: passo 3, immagine 2 di 2
    • Once the screws are removed, you should fully desolder the speaker wires that are attached to the motherboard. Instructions on how to desolder these wires are here on ifixit: Come saldare e dissaldare componenti elettrici
    • After switching out the old speaker, just follow the directions in reverse to finish.
Conclusione
Mallory
Membro da: 01/21/15
346 Reputazione
3 Guide realizzate
USF Tampa, Team 4-5, Brown Winter 2015 Membro di USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 115
