Salta al contenuto principale
Azpen A740 Camera Replacement
Cosa ti serve
  1. Azpen A740 Camera Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Camera Replacement, Camera: passo 2, immagine 1 di 1
    • You should see the motherboard, the speaker, and the battery.
    • The camera is surrounded by the red square.
  3. Azpen A740 Camera Replacement: passo 3, immagine 1 di 1
    • The camera is located at the top of the device and is attached by one screw with 3.75mm which is inside of the red circle. And one clip which is inside of the orange rectangle.
    • First remove the screw from the plastic connecting the camera to the motherboard.
    • The ZIF connector attaching the camera to the motherboard.
  4. Azpen A740 Camera Replacement: passo 4, immagine 1 di 1
    • With the plastic now removed from the camera, the user is able to unclip the camera from the motherboard by pulling up the black clip and sliding out the camera.
    • Here you can see the rear camera is on the top and the front camera is on the top. As you can see, it is not possible to replace one camera and not the other.
  5. Azpen A740 Camera Replacement: passo 5, immagine 1 di 1
    • This is what the camera looks like once completely removed from the tablet.
    • This is where the camera was previously, it is the place where the new camera must be placed.
  6. Azpen A740 Camera Replacement: passo 6, immagine 1 di 1
    • Now you are able to insert the new camera.
    • To reassemble your device, follow these instructions in reverse order.
Conclusione
USF Tampa, Team 4-5, Brown Winter 2015 Membro di USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 158
