Salta al contenuto principale
Azpen A720 Speaker Replacement
Cosa ti serve
  1. Azpen A720 Speaker Replacement, Back Cover: passo 1, immagine 1 di 2 Azpen A720 Speaker Replacement, Back Cover: passo 1, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Speaker Replacement: passo 2, immagine 1 di 3 Azpen A720 Speaker Replacement: passo 2, immagine 2 di 3 Azpen A720 Speaker Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the rear casing.
  4. Azpen A720 Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    • The speaker is a black oval located in the corner next to the battery.
  5. Azpen A720 Speaker Replacement: passo 5, immagine 1 di 1
    • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
    • Remember which lead the black and red wires connect to on the motherboard.
    • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
  6. Azpen A720 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the speaker from the tablet.
Conclusione
Anna
Membro da: 03/17/15
353 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 268
