Salta al contenuto principale
Azpen A720 Battery Replacement
Cosa ti serve
  1. Azpen A720 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Azpen A720 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Battery Replacement: passo 2, immagine 1 di 3 Azpen A720 Battery Replacement: passo 2, immagine 2 di 3 Azpen A720 Battery Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the rear casing.
  4. Azpen A720 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Locate the batteries' connection points.
  5. Azpen A720 Battery Replacement: passo 5, immagine 1 di 1
    • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
    • Use a soldering iron to melt the connections which attach the battery to the motherboard.
    • Disconnect the red and black wires from the motherboard.
  6. Azpen A720 Battery Replacement: passo 6, immagine 1 di 2 Azpen A720 Battery Replacement: passo 6, immagine 2 di 2
    • Peel the black sticker off the battery to disconnect the wifi antennae.
  7. Azpen A720 Battery Replacement: passo 7, immagine 1 di 3 Azpen A720 Battery Replacement: passo 7, immagine 2 di 3 Azpen A720 Battery Replacement: passo 7, immagine 3 di 3
    • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
    • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
  8. Azpen A720 Battery Replacement: passo 8, immagine 1 di 2 Azpen A720 Battery Replacement: passo 8, immagine 2 di 2
    • Remove the old battery and replace it with the new battery.
Linea Traguardo
Ben
Membro da: 03/18/15
280 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,239
