Salta al contenuto principale
Azpen A701 Motherboard Replacement
Cosa ti serve
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: passo 1, immagine 1 di 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: passo 2, immagine 1 di 2 Azpen A701 Motherboard Replacement: passo 2, immagine 2 di 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: passo 3, immagine 1 di 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: passo 4, immagine 1 di 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 3 Azpen A701 Motherboard Replacement, Motherboard: passo 5, immagine 2 di 3 Azpen A701 Motherboard Replacement, Motherboard: passo 5, immagine 3 di 3
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: passo 6, immagine 1 di 3 Azpen A701 Motherboard Replacement: passo 6, immagine 2 di 3 Azpen A701 Motherboard Replacement: passo 6, immagine 3 di 3
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: passo 7, immagine 1 di 1
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: passo 11, immagine 1 di 1
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: passo 12, immagine 1 di 1
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
Conclusione
Michael
Membro da: 03/11/15
568 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 331
