Salta al contenuto principale
Azpen A701 Charger Port Replacement
Cosa ti serve
  1. Azpen A701 Charger Port  Replacement, General Disassembly Prerequisite Guide: passo 1, immagine 1 di 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Charger Port  Replacement: passo 2, immagine 1 di 2 Azpen A701 Charger Port  Replacement: passo 2, immagine 2 di 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Charger Port  Replacement: passo 3, immagine 1 di 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Charger Port  Replacement: passo 4, immagine 1 di 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Charger Port  Replacement, Charger Port: passo 5, immagine 1 di 1
    • The charger port is located on the underside of the motherboard (as pictured).
  6. Azpen A701 Charger Port  Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the charger port by using tweezers and gently pulling.
  7. Azpen A701 Charger Port  Replacement: passo 7, immagine 1 di 1
    • Solder and place new charger port.
Conclusione
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
Michael
Membro da: 03/11/15
568 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 606
