Salta al contenuto principale
Axess SPBT1031 Auxiliary Port Replacement
Cosa ti serve
  1. Axess SPBT1031 Auxiliary Port Replacement, Red Interface Plate: passo 1, immagine 1 di 1
    • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
  2. Axess SPBT1031 Auxiliary Port Replacement: passo 2, immagine 1 di 1
    • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
  3. Axess SPBT1031 Auxiliary Port Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
  4. Axess SPBT1031 Auxiliary Port Replacement: passo 4, immagine 1 di 1
    • Separate the red interface plate from the black face plate by pulling them apart.
  5. Axess SPBT1031 Auxiliary Port Replacement, Auxiliary Port: passo 5, immagine 1 di 1
    • Take the red plate and the motherboard and pull apart them apart.
    • Be careful not to damage the motherboard or red plate as you pull them apart.
  6. Axess SPBT1031 Auxiliary Port Replacement: passo 6, immagine 1 di 1
    • Locate the auxiliary port which is on the left side above the USB drive and to the right of the charging port (auxiliary port has a circular front).
  7. Axess SPBT1031 Auxiliary Port Replacement: passo 7, immagine 1 di 1
    • To remove the port, heat up 5 different solder points using a soldering iron.
  8. Axess SPBT1031 Auxiliary Port Replacement: passo 8, immagine 1 di 1
    Desoldering Pump
    $3.99
    • Use a desoldering pump to remove the liquefied solder.
    • Then pull off the auxiliary port.
Conclusione
Altre 5 persone hanno completato questa guida.
5Commenti sulla guida
Can you replace with an old phone charging port
Barbara Myers - Replica
Can you replace charger port with a phone charger port
I did not replace the auxiliary port, what I did is replace the on/off button and this guide help me a lot. Thanks!
Diego Rubi - Replica
hey, is there a video or something you can make for just the process of taking off the port. For example, showing which exact points need the solder removed. Thanks.
Michael “Mike” Martinez - Replica
Im not a tech repair guy… I want my speaker to be fixed for me…. Were can i send it to be fixed
jaron curry - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 35
Tutti i Tempi: 20,225
