Salta al contenuto principale
Autosampler Open-Storm Board Reprogramming (For Old & New Versions)
Cosa ti serve
  1. Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Disconnect the batteries completely.: passo 1, immagine 1 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Disconnect the batteries completely.: passo 1, immagine 2 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Disconnect the batteries completely.: passo 1, immagine 3 di 3
    • 1. Disconnect the plug to the solar panel.
    • Then, grabbing the green connector, pull the battery connector from the solar charge controller.
    • 2. Disconnect the plugs for the autosampler battery.
    • 3. Disconnect the connector that plugs into the battery port of the sampler.
    • If disconnect battery before solar panel, this can damage the solar charger!
  2. Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Plug in USB and reconnect batteries.: passo 2, immagine 1 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Plug in USB and reconnect batteries.: passo 2, immagine 2 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Plug in USB and reconnect batteries.: passo 2, immagine 3 di 3
    • 4. Plug in the USB programmer into the Open-Storm board.
    • 5. Reconnect the node battery.
    • 6. Reconnect the autosampler battery.
  3. Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Connecting to the computer.: passo 3, immagine 1 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Connecting to the computer.: passo 3, immagine 2 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Connecting to the computer.: passo 3, immagine 3 di 3
    • 7. Connect the USB programmer into the computer.
    • 8. Create a folder for the Open-Storm board code to be stored. In this case, it indicates that we are working with an autosampler.
    • 9. The code is stored on GitHub here. Click the "Clone or download" button. Copy the address.
  4. Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Downloading the code.: passo 4, immagine 1 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Downloading the code.: passo 4, immagine 2 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Downloading the code.: passo 4, immagine 3 di 3
    • 10. Open the Git Bash application and type "cd" followed by the address of the folder you created to save the code in. In this case "~/Documents/psoc/perfect-cell-autosampler".
    • You can use the "~" if the folder is located in your home directory.
    • You will need the free program Git BASH in order to download the code. You can download it here.
    • 11. Type "git clone" followed by the address copied from git hub here.
    • Now the code will download to the desired folder.
    • 12. Inside your folder, open the "perfect-cell" folder then open the "perfect-cell.cydsn" folder.
  5. Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Programming the motherboard.: passo 5, immagine 1 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Programming the motherboard.: passo 5, immagine 2 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Programming the motherboard.: passo 5, immagine 3 di 3
    • 13. Obtain the "config.h" file from an administrator at the Real-Time Water Systems Lab. Then copy the file and paste it in the "perfect-cell.cydsn" file.
    • You will need the free program PSoC to program the cell. You can download it here.
    • PSoC only works on Windows.
    • 14. Then in the perfect-cell.cydsn" file, open the "perfect-cell" PSoC file. Once the PSoC Creator program launches, begin by building the cell. Go to: Build>Build perfect-cell. After it's done building you should not see any errors. Warnings are okay.
    • 15. Now it is time to program the cell! There are two ways to do this:
    • (1) Press the "Program" button" or;
    • (2) Click "Debug" then select "Program"
  6. Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Programming the motherboard.: passo 6, immagine 1 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Programming the motherboard.: passo 6, immagine 2 di 3 Autosampler Open-Storm Board Reprogramming (For Old & New Versions), Programming the motherboard.: passo 6, immagine 3 di 3
    • 16. PSOC will begin flashing the code. You can track the progress by watching the "programming - XX of 1024 blocks".
    • 17. When the board is completely programmed, it will say "Finished Programming".
    • 18. You will also note the board is completely programmed when the board flashes blue.
    • Now you can unplug the USB from the board and the computer.
Linea Traguardo
Brooke Mason
Membro da: 05/29/19
2.928 Reputazione
17 Guide realizzate
Open-Storm Membro di Open-Storm
Community
14 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 260
