Salta al contenuto principale
Autosampler Configuration for Node Control (For Old & New Versions)
Cosa ti serve
  1. Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: passo 1, immagine 1 di 3 Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: passo 1, immagine 2 di 3 Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: passo 1, immagine 3 di 3
    • 1. Turn on the autosampler. Screen will read "...STANDBY..."
    • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
    • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
    • 3. Use arrows to find "EVENT MARK". Press the "ENTER/PROGRAM" button.
  2. Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: passo 2, immagine 1 di 3 Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: passo 2, immagine 2 di 3 Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: passo 2, immagine 3 di 3
    • 4. Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
    • 5. Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
    • It is critical this setting is configured in order for the sensor node to operate the autosampler!
    • 6. Use arrows to find "EXIT CONFIGURATION." Press "ENTER/PROGRAM" button. This will bring up the screen "...STANDBY...
Linea Traguardo
Brooke Mason
Membro da: 05/29/19
2.928 Reputazione
17 Guide realizzate
Open-Storm Membro di Open-Storm
Community
14 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 102
