Salta al contenuto principale
Audiovox CR8030iE5 Docking Port Replacement
Cosa ti serve
  1. Audiovox CR8030iE5 Docking Port Replacement, Top-Casing: passo 1, immagine 1 di 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Docking Port Replacement: passo 2, immagine 1 di 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Docking Port Replacement: passo 3, immagine 1 di 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Docking Port Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Docking Port Replacement: passo 5, immagine 1 di 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Docking Port Replacement, Docking Port: passo 6, immagine 1 di 1
    • One by one, de-solder the line of nine wires attached to the docking port board. After pulling out the wires, save them. This is done so that you can solder them into the new docking port board.
    • If you don't know how to solder, check out Come saldare e dissaldare componenti elettrici.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  7. Audiovox CR8030iE5 Docking Port Replacement: passo 7, immagine 1 di 1
    • Carefully insert the wires into the designated holes on the new docking port board and solder them into place.
Conclusione
Nab Sengupta
Membro da: 04/18/13
55 Reputazione
4 Guide realizzate
Cal Poly, Team 10-39, Amido Spring 2013 Membro di Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 375
