Introduzione
This repair guide will help you with the following:
- Install the left headphone cable
- Fix sound coming from the left headphone
Cosa ti serve
Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference Come saldare e dissaldare componenti elettrici.
Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference Come saldare e dissaldare componenti elettrici.
Altre 3 persone hanno completato questa guida.
2 Commenti
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
