Salta al contenuto principale
Audio Technica ATH-AD500 Driver Replacement
Cosa ti serve
  1. Audio Technica ATH-AD500 Driver Replacement, Speaker Assembly: passo 1, immagine 1 di 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Driver Replacement: passo 2, immagine 1 di 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Driver Replacement: passo 3, immagine 1 di 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Driver Replacement, Driver: passo 4, immagine 1 di 1
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  5. Audio Technica ATH-AD500 Driver Replacement: passo 5, immagine 1 di 1
    • Pull the driver out of its bracket.
  6. Audio Technica ATH-AD500 Driver Replacement: passo 6, immagine 1 di 2 Audio Technica ATH-AD500 Driver Replacement: passo 6, immagine 2 di 2
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Come saldare e dissaldare componenti elettrici.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  7. Audio Technica ATH-AD500 Driver Replacement: passo 7, immagine 1 di 2 Audio Technica ATH-AD500 Driver Replacement: passo 7, immagine 2 di 2
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
Conclusione
Altre 2 persone hanno completato questa guida.
Nick Levy
Membro da: 01/13/13
177 Reputazione
1 Guida realizzata
Cal Poly, Team 17-19, Forte Winter 2013 Membro di Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Membri
17 Guide realizzate
2 Commenti
where can i buy a replacement driver?
acidxgangster - Replica
You can order parts directly from PARTS@ATUS.COM
Nick Levy -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 41
Tutti i Tempi: 10,890
