Salta al contenuto principale
AuKing M8-F Bulb Replacement
Cosa ti serve
  1. AuKing M8-F Bulb Replacement, Motherboard: passo 1, immagine 1 di 2 AuKing M8-F Bulb Replacement, Motherboard: passo 1, immagine 2 di 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws on the base of the projector using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. AuKing M8-F Bulb Replacement: passo 2, immagine 1 di 3 AuKing M8-F Bulb Replacement: passo 2, immagine 2 di 3 AuKing M8-F Bulb Replacement: passo 2, immagine 3 di 3
    • Carefully prop open the top of the projector.
    • To remove the cord that is attached to the top, carefully wiggle the cord out.
    • Remove the top lid.
  3. AuKing M8-F Bulb Replacement: passo 3, immagine 1 di 3 AuKing M8-F Bulb Replacement: passo 3, immagine 2 di 3 AuKing M8-F Bulb Replacement: passo 3, immagine 3 di 3
    • Flip up the black locking flaps then remove the two ribbon cables.
  4. AuKing M8-F Bulb Replacement: passo 4, immagine 1 di 2 AuKing M8-F Bulb Replacement: passo 4, immagine 2 di 2
    • Remove the two 9 mm screws using the Phillips #00 screwdriver.
  5. AuKing M8-F Bulb Replacement: passo 5, immagine 1 di 2 AuKing M8-F Bulb Replacement: passo 5, immagine 2 di 2
    • Carefully disconnect the wires that are attached to the motherboard.
    • Remove the motherboard.
  6. AuKing M8-F Bulb Replacement, Bulb: passo 6, immagine 1 di 2 AuKing M8-F Bulb Replacement, Bulb: passo 6, immagine 2 di 2
    • Remove the six 9 mm screws using a Phillips #0 screwdriver to detach both of the black panels.
  7. AuKing M8-F Bulb Replacement: passo 7, immagine 1 di 3 AuKing M8-F Bulb Replacement: passo 7, immagine 2 di 3 AuKing M8-F Bulb Replacement: passo 7, immagine 3 di 3
    • Slide the motherboard upwards to remove the wire component connected to the LED bulb.
    • Gently remove the LED bulb and the attached heatsink from the projector
Conclusione
Aubrey Haynes
Membro da: 09/13/23
277 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 44
Tutti i Tempi: 881
