Salta al contenuto principale
Atari Lynx Battery Wire Replacement
Cosa ti serve
  1. Atari Lynx Battery Wire Replacement, Atari Lynx: passo 1, immagine 1 di 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Battery Wire Replacement: passo 2, immagine 1 di 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Battery Wire Replacement: passo 3, immagine 1 di 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Battery Wire Replacement: passo 4, immagine 1 di 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Battery Wire Replacement, Battery Wires: passo 5, immagine 1 di 1
    • Desolder both the black and red wire as shown.
    • If you need help with basic desoldering, click here.
  6. Atari Lynx Battery Wire Replacement: passo 6, immagine 1 di 1
    • Desolder the black wire as shown.
  7. Atari Lynx Battery Wire Replacement: passo 7, immagine 1 di 2 Atari Lynx Battery Wire Replacement: passo 7, immagine 2 di 2
    • Desolder the white wire and then the red wire as shown.
  8. Atari Lynx Battery Wire Replacement: passo 8, immagine 1 di 1
    • Desolder the white wire as shown in order for the battery pack to be completely removed from the device.
Conclusione
John Lopez
Membro da: 01/27/14
443 Reputazione
4 Guide realizzate
Cal Poly, Team 1-42, Maness Winter 2014 Membro di Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,715
