Introduzione
Use this guide to replace a faulty motherboard for Asus Zenbook UX31E.
A motherboard is the most important component in the computer and is necessary for the computer to work well. A faulty motherboard can cause the computer to freeze or glitch, or a blue screen of death occurs where a blue background with a sad face “:(“ appear on the screen.
Before starting the repair, make sure to power off your device completely and disconnect from any external power source.
Cosa ti serve
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Peel back the warranty sticker to reveal the screw under it.
Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
Using your hand, pull the SSD out from its slot.
domanda….come faccio a clonare il sistema operativo ?
Questa è la guida per lo smontaggio, meglio se pubblichi La tua domanda nel forum, probabilmente se usi cerca troverai la risposta. Comunque ci sono vari modi e programmi per farlo, ma spiegarlo qui non sarebbe ne adatto ne pratico.
Disconnect the ribbon between the IO and the motherboard on both sides.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
Remove the press fit connector attaching the motherboard to the screen.
Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
Un commento
Boa Tarde
Tenho um equipamento igual não está apresentando imagen no LCD fica o power e caps look ligado e apenas arranca o cooller nada mais
Can you tell me what size these screws are? I need to replace two.
Elliot Lozano - Replica
I don’t know, but you can search with product code: VISTORXUX31E
See also: https://en.accessoires-asus.com/torx-scr...|l
Davide Bortot -
