Salta al contenuto principale
Asus ZenBook UX330U SSD Replacement
Cosa ti serve
  1. Asus ZenBook UX330U SSD Replacement, Battery: passo 1, immagine 1 di 3 Asus ZenBook UX330U SSD Replacement, Battery: passo 1, immagine 2 di 3 Asus ZenBook UX330U SSD Replacement, Battery: passo 1, immagine 3 di 3
    • Before starting any device dissasembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin.
    • Remove the alligator clip at the end of the bracelet by simply pulling it off, to reveal the bullet connector.
    • Insert the bullet connector into the ground port of an outlet.
    • Make sure to keep the bracelet on at all times while disassembling your device, to prevent ESD to the components.
  2. Asus ZenBook UX330U SSD Replacement: passo 2, immagine 1 di 2 Asus ZenBook UX330U SSD Replacement: passo 2, immagine 2 di 2
    • Power off the device and make sure it is physically unplugged before starting any disassembly procedures.
    • Remove the eight 3.1 mm screws using the T5 Torx screwdriver.
    • Remove the longer 5.1 mm screw using the T5 Torx screwdriver.
  3. Asus ZenBook UX330U SSD Replacement: passo 3, immagine 1 di 3 Asus ZenBook UX330U SSD Replacement: passo 3, immagine 2 di 3 Asus ZenBook UX330U SSD Replacement: passo 3, immagine 3 di 3
    • Use a Jimmy or a spudger to pry off the two rubber feet that are closest to the hinge.
    • Unscrew the two 5.6mm screws that were underneath the rubber feet using the Philips #0 screwdriver bit.
    • The rubber feet may be difficult to remove. Do not hesitate to use more force to remove the feet, if necessary.
  4. Asus ZenBook UX330U SSD Replacement: passo 4, immagine 1 di 2 Asus ZenBook UX330U SSD Replacement: passo 4, immagine 2 di 2
    • Press the suction handle on the center of the back cover, and gently lift up.
    • You may need to wiggle the back cover as you lift it in order to take it off easily.
  5. Asus ZenBook UX330U SSD Replacement: passo 5, immagine 1 di 2 Asus ZenBook UX330U SSD Replacement: passo 5, immagine 2 di 2
    • Unscrew the six 3.7mm screws using the Philips #0 screwdriver bit.
    • Be extra cautious when handling the battery. If the battery looks swollen or damaged, consult this guide.
  6. Asus ZenBook UX330U SSD Replacement: passo 6, immagine 1 di 3 Asus ZenBook UX330U SSD Replacement: passo 6, immagine 2 di 3 Asus ZenBook UX330U SSD Replacement: passo 6, immagine 3 di 3
    • Remove the four 2.8mm screws from the motherboard ribbon connector using the Philips #0 screwdriver bit.
    • You may have to pull back the black tape located on the bottom right motherboard connector screw. This tape is not necessary for the functionality of the device and can be discarded if necessary.
  7. Asus ZenBook UX330U SSD Replacement: passo 7, immagine 1 di 3 Asus ZenBook UX330U SSD Replacement: passo 7, immagine 2 di 3 Asus ZenBook UX330U SSD Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the motherboard ribbon connector by pulling up on the metal ends with the blunt nose tweezers.
    • You may have to hold down the black tape in order to be able to lift up the connector.
    • To reconnect the motherboard ribbon, simply press the ends of the ribbon on top of the connector. This should require minimal force.
  8. Asus ZenBook UX330U SSD Replacement: passo 8, immagine 1 di 3 Asus ZenBook UX330U SSD Replacement: passo 8, immagine 2 di 3 Asus ZenBook UX330U SSD Replacement: passo 8, immagine 3 di 3
    • Pull back the silver battery connector lock with the blunt nose tweezers. This should slide back and should require minimal force.
    • Lift the battery connector vertically using the blunt nose tweezers to remove it from the socket.
  9. Asus ZenBook UX330U SSD Replacement: passo 9, immagine 1 di 2 Asus ZenBook UX330U SSD Replacement: passo 9, immagine 2 di 2
    • Gently lift the battery out of the chassis of the device.
    • Make sure that you do not bend the battery.
  10. Asus ZenBook UX330U SSD Replacement, SSD: passo 10, immagine 1 di 3 Asus ZenBook UX330U SSD Replacement, SSD: passo 10, immagine 2 di 3 Asus ZenBook UX330U SSD Replacement, SSD: passo 10, immagine 3 di 3
    • Unscrew the single 3.7mm screw holding down the M.2 SSD using the Philips #0 screwdriver bit.
  11. Asus ZenBook UX330U SSD Replacement: passo 11, immagine 1 di 2 Asus ZenBook UX330U SSD Replacement: passo 11, immagine 2 di 2
    • Lift the M.2 SSD slightly, creating a 15-25 degree angle between the SSD and the rest of the motherboard.
    • Slowly pull the M.2 SSD out. Apply a gentle force that is in line with the orientation of the SSD.
    • Do not attempt to lift the M.2 SSD more than it will go. Applying too much pressure may harm the M.2 SSD or the socket for the SSD.
Conclusione
Altre 7 persone hanno completato questa guida.
5Commenti sulla guida
Do you know the procedure to transfer the contents of the removed M.2 into the new M.2? Assuming the old one was working fine and you just want to upgrade to a larger memory M.2 - you can put the old one into a USB3 external case (I bought one for $10 on eBay) to make the transfer. Then you just need a bootable USB stick to put into the Zenbook. Boot up on the USB and format the new M.2 to match, I think this has to be Windows. Then you can use another bootable USB with Linux on it to make a bit-by-bit copy from the old one to the newly installed M.2 and all your applications and data will be good to go. Then you can format the old one and use it as an external drive. Did I get that right?
PJ Noxon - Replica
Why is it necessary to remove the motherboard ribbon and battery, to replace the M.2 SSD media? It’s not blocked in by the battery.
Don Pitchford - Replica
You need to remove the battery for safety reasons to replace the M.2 SSD. Technically, you don’t have to but then you risk damaging components since there is a chance of power going to them.
Hasan Akpunar -
Couldn't you just disconnect the battery power cable from the motherboard (step 8) to avoid this risk? The illustration in step 8 even shows the screw still in place.
dunxd -
Where can I a troubleshooting guide?
Vairamuthu Puvanachandran - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 92
Tutti i Tempi: 16,118
