Introduzione
This guide will show the reader how to replace their failing motherboard with a new one. Other components are disconnected from the motherboard so they can be saved and reconnected to the new one. One of the most common signs of a failing motherboard is random restarts. If you are experiencing these often, a failing motherboard may be the culprit.
Cosa ti serve
Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
Remove the four 4.0 mm Phillips #1 screws shown.
Remove the two 5.0 mm Phillips #1 screws shown.
Remove the three 3.0 mm Phillips #1 screws shown.
