Introduzione
This guide will show you how to replace the Motherboard of your Asus Vivobook Max X541SA-PD0703X. In order to replace the Motherboard, you will have to remove the hard drive, wifi card, and CD insert.
Cosa ti serve
Remove the disc drive by sliding it towards the right and removing it from the laptop case
Remove the three 6mm Phillips #0 screws from the fan shroud.
Remove the shroud from the motherboard.
Altre 2 persone hanno completato questa guida.
