Salta al contenuto principale
Asus Vivobook Max X541SA-PD0703X Motherboard Replacement
Cosa ti serve
  1. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 3, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 3, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 3, immagine 3 di 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 4, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 4, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 4, immagine 3 di 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 6, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 6, immagine 2 di 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Disc Drive: passo 8, immagine 1 di 1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: passo 9, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: passo 9, immagine 2 di 2
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 10, immagine 1 di 1
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 11, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 11, immagine 2 di 2
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 14, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 14, immagine 2 di 2
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: passo 15, immagine 1 di 1
    • Pull the motherboard to the right and lift up.
Conclusione
Altre 2 persone hanno completato questa guida.
Hetvi Mehta
Membro da: 02/22/18
781 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G4, Cagle Spring 2018 Membro di USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,177
