Salta al contenuto principale
Asus Vivobook Max X541SA-PD0703X Keyboard Replacement
Cosa ti serve
  1. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 3, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop.
    • Ribbon cables connect the two half so don't remove completely.
  4. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 4, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 4, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 4, immagine 3 di 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 5, immagine 1 di 1
    • Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
  6. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove the three 3mm Phillips #0 screws from the touchpad.
  7. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 7, immagine 1 di 1
    • Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Pull the ribbon out of the socket.
  8. Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 8, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Keyboard Replacement: passo 8, immagine 2 di 2
    • Remove the touchpad.
Conclusione
Altre 2 persone hanno completato questa guida.
Hetvi Mehta
Membro da: 02/22/18
781 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G4, Cagle Spring 2018 Membro di USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,107
