Salta al contenuto principale
Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement
Cosa ti serve
  1. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 3 di 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 3 di 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 6, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 6, immagine 2 di 2
    • Pull the Wi-Fi card out of the motherboard.
    The removal of the wifi card seems unnecessary for removing the hard drive.
    Jakub Šušlík - Replica
  7. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 7, immagine 1 di 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
    I have an ASUS x451N. I changed the storage to an ssd since its very slow and now it doesn't boot. It just gets stuck in bios. It appears in the storage section but not on the boot menu. The ssd has an os and I have already tried to boot it in my pc and it works. I hope you can help me with this problem. Thank you!
    Christusjohn Leoncio L Salvani - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S1-G4, Cagle Spring 2018 Membro di USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Membri
7 Guide realizzate
2 Commenti
Thanx a million
Eli Rottenberg - Replica
is it possible to upgrade the hard drive of any laptop? from 500GB to 1T?
kevin ross s. rosento - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,515
