Salta al contenuto principale
Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement
Cosa ti serve
  1. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 3 di 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 3 di 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 6, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 6, immagine 2 di 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 7, immagine 1 di 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S1-G4, Cagle Spring 2018 Membro di USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Membri
7 Guide realizzate
2 Commenti
Thanx a million
Eli Rottenberg - Replica
is it possible to upgrade the hard drive of any laptop? from 500GB to 1T?
kevin ross s. rosento - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,574
