Salta al contenuto principale
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
Cosa ti serve
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 2, immagine 1 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 2, immagine 2 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 3, immagine 1 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 3, immagine 2 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 3, immagine 3 di 3
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 4, immagine 1 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 4, immagine 2 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 4, immagine 3 di 3
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 5, immagine 1 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 5, immagine 2 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 5, immagine 3 di 3
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 6, immagine 1 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 6, immagine 2 di 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 6, immagine 3 di 3
    • Carefully remove the battery using a plastic opening tool.
Conclusione
Vivek Rana
Membro da: 09/11/21
169 Reputazione
1 Guida realizzata
Un commento
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 54
Tutti i Tempi: 2,186
