Salta al contenuto principale
Introduzione
This guide will help you to replace a broken speaker in your Asus Tablet MeMo Pad 7 ME7000C.
  1. Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off. Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
    • Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
  2. Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device. If you are having trouble using the blue plastic opening tools, try using the black spudger instead. If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
    • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
    • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  3. Pull the rear panel and the display screen away from each other. Pull the rear panel and the display screen away from each other.
    • Pull the rear panel and the display screen away from each other.
  4. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  5. Using the spudger, gently press on the black button on the plug port to release the battery from the plug. Using the spudger, gently press on the black button on the plug port to release the battery from the plug. Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
    • Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
  6. Remove the battery from the device. Remove the battery from the device.
    • Remove the battery from the device.
  7. Using the tweezers, disconnect the black clip. Using the tweezers, disconnect the black clip.
    • Using the tweezers, disconnect the black clip.
  8. Use the  Phillips #000 Screwdriver to unscrew the 3mm Phillips head screws on the right and left corners of the speaker. Use the magnetic pad to keep track of your screws while working. Use the magnetic pad to keep track of your screws while working.
    • Use the Phillips #000 Screwdriver to unscrew the 3mm Phillips head screws on the right and left corners of the speaker.
    • Use the magnetic pad to keep track of your screws while working.
  9. Remove the speaker from the device.
    • Remove the speaker from the device.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 56
