Salta al contenuto principale
Asus ROG Strix GL702VS Motherboard Replacement
Cosa ti serve
  1. Asus ROG Strix GL702VS Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Motherboard Replacement: passo 3, immagine 1 di 2 Asus ROG Strix GL702VS Motherboard Replacement: passo 3, immagine 2 di 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: passo 5, immagine 1 di 3 Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: passo 5, immagine 2 di 3 Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: passo 5, immagine 3 di 3
    • Remove the four 4.8mm JIS #0 screws (two on each fan).
  6. Asus ROG Strix GL702VS Motherboard Replacement: passo 6, immagine 1 di 3 Asus ROG Strix GL702VS Motherboard Replacement: passo 6, immagine 2 di 3 Asus ROG Strix GL702VS Motherboard Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the fan's connector on the motherboard using a pair of tweezers.
    • Be gentle, as the small clips and wires can be easily damaged.
  7. Asus ROG Strix GL702VS Motherboard Replacement: passo 7, immagine 1 di 2 Asus ROG Strix GL702VS Motherboard Replacement: passo 7, immagine 2 di 2
    • Gently lift each fan up and out of position.
  8. Asus ROG Strix GL702VS Motherboard Replacement, Motherboard: passo 8, immagine 1 di 1
    • Disconnect the screen connector by lightly pulling the clip out.
    • The wires are delicate; disconnecting shouldn't take much force.
  9. Asus ROG Strix GL702VS Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove the seven 4mm JIS #0 screws from the motherboard.
    • One may be hidden, requiring disconnecting the screen connector.
  10. Asus ROG Strix GL702VS Motherboard Replacement: passo 10, immagine 1 di 2 Asus ROG Strix GL702VS Motherboard Replacement: passo 10, immagine 2 di 2
    • Unscrew the two 6.5mm JIS #0 screws located at the top corners of the motherboard.
  11. Asus ROG Strix GL702VS Motherboard Replacement: passo 11, immagine 1 di 1
    • Using the opening tool, lift up the flaps that secure the screen to the base.
  12. Asus ROG Strix GL702VS Motherboard Replacement: passo 12, immagine 1 di 1
    • Disconnect the Wi-Fi antenna by unplugging the black and white wires located behind the ethernet port.
    • For reassembly, note the corresponding triangles for each wire.
  13. Asus ROG Strix GL702VS Motherboard Replacement: passo 13, immagine 1 di 3 Asus ROG Strix GL702VS Motherboard Replacement: passo 13, immagine 2 di 3 Asus ROG Strix GL702VS Motherboard Replacement: passo 13, immagine 3 di 3
    • Use a spudger tool to lift the connector tabs on the motherboard and slide the four ribbons out.
  14. Asus ROG Strix GL702VS Motherboard Replacement: passo 14, immagine 1 di 2 Asus ROG Strix GL702VS Motherboard Replacement: passo 14, immagine 2 di 2
    • Grasp the motherboard where the fans are located and lift up.
    • Do not force it. If you feel resistance, restart this guide to ensure you have removed all screws and connectors.
Conclusione
To reassemble the device, follow these instructions in reverse order.
4 Commenti
Any recommendation on WHERE to get a replacement mobo for this unit? Not having any luck in tracking one down.
help - Replica
Try ebay -- that's where I got mine.. arrived in a few weeks from China.
turgut kalfaoglu - Replica
What I wonder is that, when replacing the motherboard, should I remove all the aluminium tape that's at the bottom of the case? I suspect some of it has lifted and caused a short previously..
Yes I just replaced the motherboard. There are lots more tips that could have been added here but I used this page to remember where the screws are. Many thanks..
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,523
