Salta al contenuto principale
Asus Q503UA-BSI5T17 Fan Removal
Cosa ti serve
  1. Asus Q503UA-BSI5T17 Fan Removal, Battery Replacement: passo 1, immagine 1 di 1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 Fan Removal: passo 2, immagine 1 di 2 Asus Q503UA-BSI5T17 Fan Removal: passo 2, immagine 2 di 2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 Fan Removal: passo 3, immagine 1 di 3 Asus Q503UA-BSI5T17 Fan Removal: passo 3, immagine 2 di 3 Asus Q503UA-BSI5T17 Fan Removal: passo 3, immagine 3 di 3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 Fan Removal, Fan: passo 4, immagine 1 di 2 Asus Q503UA-BSI5T17 Fan Removal, Fan: passo 4, immagine 2 di 2
    • Disconnect the two cables connecting the fan to the motherboard.
  5. Asus Q503UA-BSI5T17 Fan Removal: passo 5, immagine 1 di 2 Asus Q503UA-BSI5T17 Fan Removal: passo 5, immagine 2 di 2
    • Remove the two screws from the fan with a Phillips #0 screwdriver.
    • Remove the four screws from the heatsink with a Phillips #0 screwdriver.
  6. Asus Q503UA-BSI5T17 Fan Removal: passo 6, immagine 1 di 1
    • Carefully remove the fan assembly from the laptop.
    • When reinstalling the fan, be sure to clean the contact surfaces on both the CPU and heatsink and reapply fresh thermal paste.
Conclusione
Gateway, Team S1-G4, Saknee Fall 2019 Membro di Gateway, Team S1-G4, Saknee Fall 2019
GCC-SAKNEE-F19S1G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 199
