Salta al contenuto principale
Asus K55a-si50301p USB 3.0 Replacement
Cosa ti serve
  1. Asus K55a-si50301p USB 3.0 Replacement, Battery: passo 1, immagine 1 di 1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p USB 3.0 Replacement: passo 2, immagine 1 di 1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p USB 3.0 Replacement: passo 3, immagine 1 di 1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p USB 3.0 Replacement, USB 3.0/Audio Ports: passo 4, immagine 1 di 1
    • Remove the eight Phillips #0 screws.
  5. Asus K55a-si50301p USB 3.0 Replacement: passo 5, immagine 1 di 1
    • Gently pull towards yourself and up to remove the first plastic cover.
  6. Asus K55a-si50301p USB 3.0 Replacement: passo 6, immagine 1 di 2 Asus K55a-si50301p USB 3.0 Replacement: passo 6, immagine 2 di 2
    • Use the iFixit opening tool around the outside line where the top of the laptop meets the bottom to separate components.
  7. Asus K55a-si50301p USB 3.0 Replacement: passo 7, immagine 1 di 1
    • Flip the laptop over and lift the keyboard tray gently towards the screen.
    • Remove the 3 ribbon cables from the motherboard end.
  8. Asus K55a-si50301p USB 3.0 Replacement: passo 8, immagine 1 di 1
    • With the keyboard tray out of the way, remove the tape holding down the accessory board ribbon cable.
  9. Asus K55a-si50301p USB 3.0 Replacement: passo 9, immagine 1 di 1
    • Pull the ribbon cable out of its slot on the USB/Audio port board as shown.
Conclusione
Un commento
after doing this start button lights up but will not boot
David Garside - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 714
