Salta al contenuto principale
Asus Chromebook Flip C302CA Wi-Fi Card Replacement
Cosa ti serve
  1. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 2, immagine 1 di 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 2, immagine 2 di 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 2, immagine 3 di 3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 3, immagine 1 di 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 3, immagine 2 di 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 3, immagine 3 di 3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 4, immagine 1 di 2 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: passo 5, immagine 1 di 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: passo 5, immagine 2 di 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the sticker holding the cable using a pair of tweezers.
    • Detach the cable from the motherboard by lifting it up with a spudger.
    • Always use a plastic or nylon ESD-safe tool. Metal spudger and other sharp tools can puncture a battery, potentially causing a fire.
  6. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 6, immagine 1 di 2 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 6, immagine 2 di 2
    • Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
  7. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: passo 7, immagine 1 di 1
    • Carefully lift up the battery from the front side to remove it from the laptop.
  8. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: passo 8, immagine 1 di 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: passo 8, immagine 2 di 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: passo 8, immagine 3 di 3
    • Carefully remove the black and white cables connected to the Wi-Fi card.
    • Remove the single 2 mm screw while holding the Wi-Fi card using the Phillips #00 screwdriver.
    • Remove the Wi-Fi card from the laptop.
Conclusione
Gateway, Team 1-2, Saknee Spring 2022 Membro di Gateway, Team 1-2, Saknee Spring 2022
GCC-SAKNEE-S22S1G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 398
