Salta al contenuto principale
Astro Pyle PTBL7C Battery Replacement
Cosa ti serve
  1. Astro Pyle PTBL7C  Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use the spudger to open the device from the front edge of the screen. Gently slide it in and push it up to open.
    • It may emit a cracking sound at it opens; this is only the locks coming apart.
  2. Astro Pyle PTBL7C  Battery Replacement: passo 2, immagine 1 di 2 Astro Pyle PTBL7C  Battery Replacement: passo 2, immagine 2 di 2
    • The battery will appear as pictured. Separate the back case from the device. Avoid damaging the wire that connects the speakers between the two halves of the case.
  3. Astro Pyle PTBL7C  Battery Replacement: passo 3, immagine 1 di 1
    • The battery is attached in two different ways; one wire is attached to the screen to support the screen's background led lights. Carefully desolder the wire without damaging the part connecting the battery to the screen.
  4. Astro Pyle PTBL7C  Battery Replacement: passo 4, immagine 1 di 1
    • Desolder the wires pictured. These feed energy from the battery into the motherboard.
    • Use caution to avoid damaging the motherboard or other critical pieces.
  5. Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Use a plastic card to gently break the adhesive holding the battery to the metal screen plate. Remove the battery.
    • Though non-functional, the battery still contains dangerous chemicals. Handle it directly as little as possible.
    • Install the new battery and solder all the connections back in place.
    • Visit this guide for more information on soldering and desoldering: iFixit Soldering Guide
Conclusione
Abdulelah
Membro da: 10/22/16
214 Reputazione
2 Guide realizzate
IUPUI, Team 5-5, Wilson Fall 2016 Membro di IUPUI, Team 5-5, Wilson Fall 2016
IUPUI-WILSON-F16S5G5
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 398
