Salta al contenuto principale
Astro A50 2016 Headset Motherboard Replacement
Cosa ti serve
  1. Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: passo 1, immagine 1 di 2 Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: passo 1, immagine 2 di 2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Motherboard Replacement: passo 2, immagine 1 di 1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Motherboard Replacement, Headset Motherboard: passo 5, immagine 1 di 1
  6. Astro A50 2016 Headset Motherboard Replacement: passo 6, immagine 1 di 2 Astro A50 2016 Headset Motherboard Replacement: passo 6, immagine 2 di 2
    • Use a soldering iron to desolder the black and yellow wires from the two metal plates near the bottom of the device.
    • Use a soldering iron to desolder the 13 wires in rows along the left and bottom sides of the headset motherboard.
    • Come saldare e dissaldare componenti elettrici
  7. Astro A50 2016 Headset Motherboard Replacement: passo 7, immagine 1 di 1
    • Use the plastic opening tool to pry off the black tape covering the gray wires
  8. Astro A50 2016 Headset Motherboard Replacement: passo 8, immagine 1 di 1
    • Lift the motherboard out of the headset and gently disconnect the gray wires from the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Brian Menard
Membro da: 10/01/17
288 Reputazione
1 Guida realizzata
Cal Poly, Team S15-G1, Livingston Fall 2017 Membro di Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Membri
10 Guide realizzate
2 Commenti
Any chance I could get the E250336. USB board part from you guys? I need one.
Theron Miller - Replica
I am having a very tough time finding this Part online. Thanks!
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,116
