Salta al contenuto principale
Astro A40 TR Speakers Replacement
Cosa ti serve
  1. Astro A40 TR Speakers Replacement, Speakers: passo 1, immagine 1 di 2 Astro A40 TR Speakers Replacement, Speakers: passo 1, immagine 2 di 2
    • To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
  2. Astro A40 TR Speakers Replacement: passo 2, immagine 1 di 3 Astro A40 TR Speakers Replacement: passo 2, immagine 2 di 3 Astro A40 TR Speakers Replacement: passo 2, immagine 3 di 3
    • Remove the dust cover located on the speaker. Use the corner of the spudger to peel underneath the cover until you can lift it by hand. The cover is held onto the device with adhesive and should be removed slowly.
  3. Astro A40 TR Speakers Replacement: passo 3, immagine 1 di 2 Astro A40 TR Speakers Replacement: passo 3, immagine 2 di 2
    • Take off the front cover by removing the four screws located in a square formation on the surface of the device. Use the J00 Philips driver listed in the device page.
  4. Astro A40 TR Speakers Replacement: passo 4, immagine 1 di 2 Astro A40 TR Speakers Replacement: passo 4, immagine 2 di 2
    • Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
  5. Astro A40 TR Speakers Replacement: passo 5, immagine 1 di 1
    • If your issue is asking for the complete replacement of the speaker or the motherboard, un-solder the old components and replace with new speaker by re-soldering.
    • Check out this useful guide on how to solder and desolder connections if soldering is new to you.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 6-5, Martin Fall 2016 Membro di UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
3 Membri
10 Guide realizzate
2 Commenti
I’ve found potential replacement speakers here. They look fairly similar to the ones in the A40s, but the resistance value marked on the speakers in the guide vs on the listing is different.
Buyer caution must be taken before actually making the plunge, as sound quality might be different. The listing is from Ali Express after all.
Adrian Kennedy - Replica
Great so far but how do you actually remove the speaker/driver from the plastic casing without destroying the plastic parts, since it seems to be bonded or glued-in?
Clive H - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 92
Tutti i Tempi: 9,427
