Salta al contenuto principale
Arlo Ultra 2 Spotlight Replacement
Cosa ti serve
  1. Arlo Ultra 2 Spotlight Replacement, Battery: passo 1, immagine 1 di 2 Arlo Ultra 2 Spotlight Replacement, Battery: passo 1, immagine 2 di 2
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Spotlight Replacement: passo 2, immagine 1 di 1
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Spotlight Replacement, Spotlight: passo 3, immagine 1 di 2 Arlo Ultra 2 Spotlight Replacement, Spotlight: passo 3, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity.
  4. Arlo Ultra 2 Spotlight Replacement: passo 4, immagine 1 di 2 Arlo Ultra 2 Spotlight Replacement: passo 4, immagine 2 di 2
    • Use a spudger to loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Spotlight Replacement: passo 5, immagine 1 di 2 Arlo Ultra 2 Spotlight Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 4.00 mm black screws located across from each other above the camera lens.
  6. Arlo Ultra 2 Spotlight Replacement: passo 6, immagine 1 di 2 Arlo Ultra 2 Spotlight Replacement: passo 6, immagine 2 di 2
    • Use a spudger or your fingernail to flip up the small locking flap on the ZIF connector. Then, you can safely pull the cable out.
    • The cable is very short and you will see it when removing the circuit board.
  7. Arlo Ultra 2 Spotlight Replacement: passo 7, immagine 1 di 2 Arlo Ultra 2 Spotlight Replacement: passo 7, immagine 2 di 2
    • Use a spudger to gently pry the green circuit board away from the case.
    • Remove the green circuit board. This is your spotlight.
Conclusione
Un commento
Great tutorial, very helpful. A suggestion however would be to also offer for sale or add links to where the replacement components can be purchased. In this instance I could not find a replacement spotlight and had to buy a donor camera. Thanks
Gareth - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 132
