Salta al contenuto principale
Apple iPod Dock Connector Cable Replacement
Cosa ti serve
  1. Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: passo 1, immagine 1 di 3 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: passo 1, immagine 2 di 3 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: passo 1, immagine 3 di 3
    • Unscrew the four Phillips screws on the backside of the docking system.
    • The screws are located quite deep. Make sure you have a long screwdriver to be able to reach the screws.
    • Be aware of the plastic threads. Using too much force can tear this up.
  2. Apple iPod Dock Connector Cable Replacement: passo 2, immagine 1 di 1
    • Separate the housing in two parts.
    • The dock connector is slid in two parts on the top of the system, make sure you slide the two housing parts in this line of direction.
    • The two parts are glued on the sides of the speakers. Use some force to separate the two housing parts.
    • The internal parts are still connected to each other. Don't pull the housing parts too far from each other.
  3. Apple iPod Dock Connector Cable Replacement: passo 3, immagine 1 di 1
    • Slide the dock connector out of the housing part.
  4. Apple iPod Dock Connector Cable Replacement: passo 4, immagine 1 di 1
    • Unscrew the three screws using a Phillips #2 screwdriver to remove the T-shaped circuit board holder.
  5. Apple iPod Dock Connector Cable Replacement: passo 5, immagine 1 di 1
    • Remove the T-shaped circuit board holder.
  6. Apple iPod Dock Connector Cable Replacement: passo 6, immagine 1 di 1
    • Remove the circuit board from the housing part.
    • The circuit board is still connected to another circuit board with a cable.
  7. Apple iPod Dock Connector Cable Replacement: passo 7, immagine 1 di 1
    • Disconnect the 5-pin connector between the two circuit boards.
    • The connectors are tightly connected. Hold the other circuit board to prevent it from breaking while disconnecting the 5-pin connector.
  8. Apple iPod Dock Connector Cable Replacement: passo 8, immagine 1 di 2 Apple iPod Dock Connector Cable Replacement: passo 8, immagine 2 di 2
    • Look how the cables are oriented.
    • Take a picture with your phone. It's easier to look it up than recalling your memory.
  9. Apple iPod Dock Connector Cable Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
  10. Apple iPod Dock Connector Cable Replacement: passo 10, immagine 1 di 1
    • Heat up the solder.
    • If you don't want to damage your workspace, it's probably handy to place something underneath.
    • The circuit board will be getting hot. To make it more stable you can clamp it in a vise or alligator clips.
    • The heated solder tends to fumeā€”do not inhale this! Do this in a well ventilated room.
  11. Apple iPod Dock Connector Cable Replacement: passo 11, immagine 1 di 2 Apple iPod Dock Connector Cable Replacement: passo 11, immagine 2 di 2
    • If the solder becomes fluid, keep the desoldering pump near the solder.
    • Push the button on the desoldering pump to suck the solder.
    • Solder will solidify fast, so you need to act quickly.
  12. Apple iPod Dock Connector Cable Replacement: passo 12, immagine 1 di 1
    • Strip the cables with a wire stripper.
  13. Apple iPod Dock Connector Cable Replacement: passo 13, immagine 1 di 2 Apple iPod Dock Connector Cable Replacement: passo 13, immagine 2 di 2
    • Check if the cable is in the right position.
    • Heat up the contact point on the circuitboard.
    • If the contact point is hot enough, you can add a little bit of solder.
    • Don't inhale the fumes.
Conclusione
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde vanaf stap 7.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 476
