Salta al contenuto principale
Apalus Digital Hair Straightening Brush Heating Element Replacement
Cosa ti serve
  1. Apalus Digital Hair Straightening Brush Heating Element Replacement, Heating Element: passo 1, immagine 1 di 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 2, immagine 1 di 1
    • Turn comb over so the bristles are facing down.
    • Remove backside of the comb and place aside.
  3. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 3, immagine 1 di 1
    • Unplug the power cord from the connector inside of the brush.
  4. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 4, immagine 1 di 1
    • Remove the circuit board and heating element from the handle.
    • This will provide easy access to the necessary components.
  5. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 5, immagine 1 di 1
    • Remove the four 6mm Phillips #2 screws holding the heat shield onto the back side of the bristles.
  6. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 6, immagine 1 di 1
    • There are 4 solder points of the heating element located on the LCD side of the circuit board.
    • Desolder these four connections using a soldering iron.
    • Note which wires go to each of the connection points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Heating Element Replacement: passo 7, immagine 1 di 1
    • Solder the new heating element to the same connection points as they were removed from.
Conclusione
Aaron Brysch
Membro da: 11/06/17
231 Reputazione
2 Guide realizzate
IUPUI, Team S1-G3, Harley Fall 2017 Membro di IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,178
