Salta al contenuto principale
Answering Machine Speaker Replacement
Cosa ti serve
  1. Answering Machine Speaker Replacement, Base: passo 1, immagine 1 di 1
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Answering Machine Speaker Replacement: passo 2, immagine 1 di 2 Answering Machine Speaker Replacement: passo 2, immagine 2 di 2
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Answering Machine Speaker Replacement, Answering Machine Speaker: passo 3, immagine 1 di 2 Answering Machine Speaker Replacement, Answering Machine Speaker: passo 3, immagine 2 di 2
    • Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
    • Use a screwdriver to remove the two 7mm Phillips #0 screws.
  4. Answering Machine Speaker Replacement: passo 4, immagine 1 di 1
    • Finish speaker removal by cutting both the black and red wires.
  5. Answering Machine Speaker Replacement: passo 5, immagine 1 di 1
Conclusione
IUPUI, Team 3-3, Harley Fall 2016 Membro di IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 642
