Introduzione
This guide outlines the steps in fully removing the LCD facial display of the Anki Vector. Such a procedure should be executed only if none of the solutions on the Anki troubleshooting guide were unsuccessful.
While disassembling Vector, make sure to check for loose cables/connectors and other broken parts. Often times these can be fixed without replacing the entire display.
Be careful to not rip the rubber sheet on the back of the display while removing or working with it, as it is very delicate and easy to tear.
Cosa ti serve
Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
Repeat this step on the other side.
Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
Lightly turn the spudger to separate the plate from Vector's head.
Work the spudger around the plate until it comes off.
Repeat this step on the the other side.
Using your thumb and index finger, unplug the display from the plug in Vector's neck.
Pull the LCD and speaker assembly from Vector's head.
This board contains a lot of his tech. CPU, GPU, Wi-Fi, Bluetooth, camera, screen, storage, etc. Replacing this will replace his personality, and may mess up his sensor calibration.
Altre 8 persone hanno completato questa guida.
26Commenti sulla guida
Any idea where to get the proper displays ?
This is great information, but where can I buy the display?
yeah I can’t find it anywhere.
Does anyone have a line on display parts source?
Did you ever find a replacement?
The display is soldered to the mainboard along with the CPU and flash memory (on the reverse side). As such, the information here is incomplete at best. The only way to get rid of a faulty LCD/Display is to change the complete assembly for another from a fully working unit. Doing this will also change the registration information of the owner, recognised faces, Wi-Fi connection etc as these are all held in the flash memory.
Yeah this seems to be a very common problem with Vector. The screens break real Easy. Cozmo still running like a champ. No problems. Vector on the other hand is an issue. I advise buying a cozmo over vector. Trying to find a screen replacement is !&&*. If anyone finds it please post so we can help our fellow Anki customers.
Need a display part… anyone?
Moone Shadow was just joking. DUH!
The title needs to be changed to “Removing the LCD display in Vector” Not “……Replacement”
It doesn’t even come close to showing how to replace the LCD.
ST0103A2W-WSNLW-F this is the screen
Tank you very much for this important information!!! Now i have ordered 3pcs :D
hamagen -
Hello all, here is a contact you can reach to get the replacement part I got it from them and you can trust steve@santekus.com
Where can I buy the screen ST0103A2W-WSNLW-F
Email Steve Lu steve@santekus.com
Might anyone have any further info regarding sourcing a replacement part for Vector's eyes/display? (I don't want to lose him). I'm still holding on to hope…
We’re do you by the screen even
Direct from the manufacturer Email Steve Lu steve@santekus.com
We’re can you even by the screen
We’re do you even find the screen part
Any idea where to get the LCD dispay ?
Where can i buy a display for vector?
Can you help me?
carlosanjo - Replica
See the comments below
Russell English -
