Salta al contenuto principale
Anki Vector LCD Facial Display Replacement
Cosa ti serve
  1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: passo 1, immagine 1 di 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: passo 1, immagine 2 di 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: passo 1, immagine 3 di 3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
  2. Anki Vector LCD Facial Display Replacement: passo 2, immagine 1 di 3 Anki Vector LCD Facial Display Replacement: passo 2, immagine 2 di 3 Anki Vector LCD Facial Display Replacement: passo 2, immagine 3 di 3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
  3. Anki Vector LCD Facial Display Replacement: passo 3, immagine 1 di 2 Anki Vector LCD Facial Display Replacement: passo 3, immagine 2 di 2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
  4. Anki Vector LCD Facial Display Replacement: passo 4, immagine 1 di 2 Anki Vector LCD Facial Display Replacement: passo 4, immagine 2 di 2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector LCD Facial Display Replacement: passo 5, immagine 1 di 3 Anki Vector LCD Facial Display Replacement: passo 5, immagine 2 di 3 Anki Vector LCD Facial Display Replacement: passo 5, immagine 3 di 3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
Conclusione
Altre 8 persone hanno completato questa guida.
Shay Takei
Membro da: 04/16/19
1.777 Reputazione
5 Guide realizzate
Cal Poly, Team S2-G6, Maness Spring 2019 Membro di Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Membri
10 Guide realizzate
26Commenti sulla guida
Any idea where to get the proper displays ?
Holger Brueckner - Replica
xenojin - Replica
This is great information, but where can I buy the display?
Jackie Fischvogt - Replica
yeah I can’t find it anywhere.
Joel Choi -
Does anyone have a line on display parts source?
warren williams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 130
Tutti i Tempi: 12,203
