Salta al contenuto principale
Anker Soundcore Life Q30 Headphone Driver Replacement
Cosa ti serve
  1. Anker Soundcore Life Q30 Headphone Driver Replacement, Headphone Driver: passo 1, immagine 1 di 2 Anker Soundcore Life Q30 Headphone Driver Replacement, Headphone Driver: passo 1, immagine 2 di 2
    • Orient the headphones such that the headphone speakers are closest to you, and the headband is furthest from you.
    • Adjust the folding hinge to where the speakers are facing up.
    • Make sure you can easily reach the edge where the cushion connects to the rest of the headphones.
  2. Anker Soundcore Life Q30 Headphone Driver Replacement: passo 2, immagine 1 di 3 Anker Soundcore Life Q30 Headphone Driver Replacement: passo 2, immagine 2 di 3 Anker Soundcore Life Q30 Headphone Driver Replacement: passo 2, immagine 3 di 3
    • Using one hand, hold the right side of the headphones still.
    • Using your other hand, slide the plastic opening tool in the edge along the cushion.
    • Gently pry the cushion off using the plastic opening tool.
    • Set the right ear cushion aside and repeat this step for the left side of the headphones.
  3. Anker Soundcore Life Q30 Headphone Driver Replacement: passo 3, immagine 1 di 3 Anker Soundcore Life Q30 Headphone Driver Replacement: passo 3, immagine 2 di 3 Anker Soundcore Life Q30 Headphone Driver Replacement: passo 3, immagine 3 di 3
    • Remove the four 5.7 mm screws from the headphone driver using a Phillips #00 screwdriver.
    • Pull the headphone driver apart from the headphones.
    • If you’re having difficulty doing so without any tools, use tweezers to get a better grip on it.
  4. Anker Soundcore Life Q30 Headphone Driver Replacement: passo 4, immagine 1 di 2 Anker Soundcore Life Q30 Headphone Driver Replacement: passo 4, immagine 2 di 2
    • Lift the drivers out of the headphones.
    • Remove the wires from the circuit board that connect the drivers.
    • Take note of where the wires are connected, as you will have to solder them back to the circuit board.
Conclusione
Solder your replacement driver into place. This guide will give you instructions on how to solder. From there, follow these steps in reverse order to reassemble the device.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 108
Tutti i Tempi: 190
