Introduzione
For our Fast Fix Project, we wish to document the process of replacing the internal speakers of the Anker Soundcore A3102 Bluetooth Speaker. The internal speakers of Bluetooth speakers consistently lose their sound and bass quality. It can be very costly to continuously replace the entire Bluetooth speaker; we aim to document a process that will allow a time, cost-effective, and environmentally-friendly solution to replace the internal speakers. We have chosen the Anker Soundcore A3102 Bluetooth Speaker as it is one of the most common and highly rated Bluetooth speakers. This guide depicts the complete disassembly, replacement and reassembly of the bluetooth speaker. It is recommended to gather background knowledge into soldering as it is a key step to the proper completion of this guide, there is a link on step 15 to a soldering guide.
Cosa ti serve
Gently pry on each edge of the front grill with a plastic opening tool.
Using the pry tool, start at one side and lift and remove the front grille.
Gently set the grille into the speaker housing and speaker case.
Once the grille has been positioned properly, use firm pressure to seat the grille into the speaker housing and speaker case.
Allow the glue to dry for the time recommended on the bottle, typically around 30-120 minutes.
To properly disassemble, replace the internal speakers and reassemble follow the steps above as it depicts all necessary steps.
Altre 2 persone hanno completato questa guida.
