Salta al contenuto principale
American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement
Cosa ti serve
  1. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the sandpaper disc: passo 1, immagine 1 di 1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 2, immagine 1 di 1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the driver pad: passo 3, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the driver pad: passo 3, immagine 2 di 2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
  4. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the sanding disc: passo 4, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the sanding disc: passo 4, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the sanding disc: passo 4, immagine 3 di 3
    • Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
  5. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 5, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 5, immagine 2 di 2
    • Slide a thin 22 mm wrench underneath the sanding disc and clasp it onto the flat part of the motor driveshaft to keep the driveshaft from turning.
  6. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 6, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 6, immagine 2 di 2
    • Use an 11 mm socket and socket wrench to remove the 16.5 mm-long bolt securing the sanding disc to the motor driveshaft.
    • Apply counter torque to the driveshaft wrench as you loosen the bolt to keep the sanding disc from spinning.
  7. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 7, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 7, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 7, immagine 3 di 3
    • Take two pry bars and insert them underneath the sanding disc as close to the driveshaft as possible.
    • Apply pressure to the pry bars in opposite directions to carefully pry the sanding disc off of the driveshaft.
    • Remove the sanding disc from the floor sander.
  8. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the bottom weight and cover: passo 8, immagine 1 di 1
    • Repeat the previous seven steps to remove the other two sanding discs before continuing.
    • With all three sanding discs removed, use a 4 mm hex key to remove four 25.4 mm-long screws securing the bottom cover and bottom weight.
  9. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 9, immagine 1 di 1
    • Lift the bottom weight away from the sander.
  10. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 10, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 10, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 10, immagine 3 di 3
    • Pull the top edge of the bottom cover away from the sander until you have enough space to slide the cover out.
    • Slide the cover across the bottom of the sander, away from the wheels, and remove it.
  11. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the dust fan: passo 11, immagine 1 di 1
    • Remove the washer from the motor shaft.
  12. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 12, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 12, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 12, immagine 3 di 3
    • Pull the drive pad bearing straight off of the motor shaft.
    • You may not be able to remove the bearing with your hands. If this is the case, use a bearing puller to remove the bearing.
  13. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 13, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 13, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 13, immagine 3 di 3
    • Using snap ring pliers, pry the snap ring open and slide it off of the motor shaft.
    • Remove the snap ring.
  14. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 14, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 14, immagine 2 di 2
    • Slide the dust fan straight off of the motor shaft.
  15. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Prepare the motor for removal: passo 15, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Prepare the motor for removal: passo 15, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Prepare the motor for removal: passo 15, immagine 3 di 3
  16. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the motor screws: passo 16, immagine 1 di 1
    • Use an 11 mm socket to remove the four 22.8 mm-long screws securing the motor.
  17. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Unlatch the handle assembly: passo 17, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Unlatch the handle assembly: passo 17, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Unlatch the handle assembly: passo 17, immagine 3 di 3
    • Lift the top of the latch securing the handle assembly to the sander and push it back against the sander.
    • Make sure the hook on the latch is clear of the small metal tab on the sander.
    • Repeat this step for all three latches securing the handle assembly.
  18. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the handle assembly: passo 18, immagine 1 di 1
    • Remove the handle assembly from the sander.
  19. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the dust bag: passo 19, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the dust bag: passo 19, immagine 2 di 2
    • Lift the dust bag straight up to remove it from the sander.
  20. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the motor: passo 20, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the motor: passo 20, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement, Remove the motor: passo 20, immagine 3 di 3
    • Use a Phillips #2 driver to remove three 22.1 mm-long screws securing the motor cover to the sander. There is one screw on each side of the sander.
  21. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 21, immagine 1 di 1
    • Use a 7/32" hex key to remove three 23.7 mm-long hex screws securing the motors to the motor cover.
  22. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 22, immagine 1 di 1
    • Lift the motor cover straight up and remove it.
  23. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 23, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 23, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 23, immagine 3 di 3
    • Find the two wires that connect the motor you're replacing to the motor power hub that sits in between all the motors.
    • Pull the two wires straight out of their sockets to disconnect them.
  24. American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 24, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2012 Motor Replacement: passo 24, immagine 2 di 2
    • Lift the motor straight up and remove it from the sander.
    • Repeat the last 14 steps if you wish to remove one or both of the remaining motors.
Conclusione
Miles Robinson
Membro da: 03/04/19
938 Reputazione
7 Guide realizzate
The Home Depot Membro di The Home Depot
Community
18.149 Membri
141 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 203
