Salta al contenuto principale
American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement
Cosa ti serve
  1. American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Separate the handle: passo 1, immagine 1 di 1
    • Before you begin, make sure the sander is turned off and unplugged.
    • Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
  2. American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement: passo 2, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement: passo 2, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement: passo 2, immagine 3 di 3
    • The rear half of the enclosure is bolted to the handle support, so the front half will be removed first.
    • Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
    • If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
    • Remove the front half of the handle enclosure.
  3. American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Unplug the interlock assembly: passo 3, immagine 1 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Unplug the interlock assembly: passo 3, immagine 2 di 3 American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Unplug the interlock assembly: passo 3, immagine 3 di 3
    • Pull the wires connected to the interlock assembly straight out of their connectors.
    • Keep track of where each wire connects on the interlock assembly.
  4. American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Remove the interlock assembly: passo 4, immagine 1 di 1
    • After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
Conclusione
Miles Robinson
Membro da: 03/04/19
938 Reputazione
7 Guide realizzate
The Home Depot Membro di The Home Depot
Community
18.149 Membri
141 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 174
