Salta al contenuto principale
American Sanders EZSand Orbital Sander 07163A 2012 Driver Pad Replacement
Cosa ti serve
  1. American Sanders EZSand Orbital Sander 07163A 2012 Driver Pad Replacement, Remove the sandpaper disc: passo 1, immagine 1 di 1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2012 Driver Pad Replacement: passo 2, immagine 1 di 1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2012 Driver Pad Replacement, Remove the driver pad: passo 3, immagine 1 di 2 American Sanders EZSand Orbital Sander 07163A 2012 Driver Pad Replacement, Remove the driver pad: passo 3, immagine 2 di 2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
Conclusione
Miles Robinson
Membro da: 03/04/19
938 Reputazione
7 Guide realizzate
The Home Depot Membro di The Home Depot
Community
18.149 Membri
141 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 603
