Salta al contenuto principale
Amazon Kindle 8 Power Button Replacement
Cosa ti serve
  1. Amazon Kindle 8 Power Button Replacement, Front Cover: passo 1, immagine 1 di 2 Amazon Kindle 8 Power Button Replacement, Front Cover: passo 1, immagine 2 di 2
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Power Button Replacement: passo 2, immagine 1 di 2 Amazon Kindle 8 Power Button Replacement: passo 2, immagine 2 di 2
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
  3. Amazon Kindle 8 Power Button Replacement, Motherboard: passo 3, immagine 1 di 2 Amazon Kindle 8 Power Button Replacement, Motherboard: passo 3, immagine 2 di 2
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
  4. Amazon Kindle 8 Power Button Replacement: passo 4, immagine 1 di 2 Amazon Kindle 8 Power Button Replacement: passo 4, immagine 2 di 2
    • Lift the screen and motherboard from the back cover.
  5. Amazon Kindle 8 Power Button Replacement, Power Button: passo 5, immagine 1 di 2 Amazon Kindle 8 Power Button Replacement, Power Button: passo 5, immagine 2 di 2
    • On the back cover, from the outside of the kindle, use your finger to push the power button through its hole.
    • Remove the power button.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1Commento della guida
partial fix, that does not show how to remove and replace the button in the subject. Please integrate step-by-step guide.
SimoneGallina - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 66
Tutti i Tempi: 542
